How do I adjust Arlo video recording length?
You can personalize your Arlo cameras to record videos from approximately 10 to 120 seconds long. On Arlo Ultra, Pro 3, Pro 3 Floodlight, Pro 2, Pro, Essential wire-free, Q Plus, Q, and Baby cameras, you can also set your camera to record until motion stops, up to 300 seconds (5 minutes).
To adjust Arlo video recording length:
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
- Tap or click Mode.
- Select the base station or camera that you want to adjust.
- Tap or click the pencil icon next to the mode for which you want to edit recording length.
Note: You cannot adjust recording length for Disarmed or Schedule modes, only for active modes such as Armed - Tap or click the pencil icon next to the rule that you want to edit.
If the mode only has one rule, it is preselected. - Tap or click the pencil icon next to Record video.
If Record Video is not selected, you cannot edit recording length. - Select Record until activity stops (up to 300 sec) or select Record for a fixed length of time and move the slider to your preferred recording length.
- Tap or click Save.
- Tap or click Edit Rule > Done.
Your recording length is updated.
