How do I create a rule that includes a siren trigger?
To create a rule that includes a siren trigger, you must create a new mode or edit an existing mode. These instructions explain how to edit an existing mode.
Note: Only Arlo Ultra, Pro 3, Pro 2, Pro, or Wire-Free cameras connected to a SmartHub or Base Station with Siren can trigger the siren.
To create a rule that includes a siren trigger:
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
- Tap or click Mode.
- Tap or click the Arlo SmartHub or Arlo Pro base station for which you would like to add a siren trigger.
- Tap the pencil icon or click > next to the mode that you would like to edit.
- Under Rules, tap the pencil icon or click Edit next to the device that you want to trigger the siren.
- Select the Turn alarm ON check box.
- Tap the pencil icon or click > next to Turn alarm ON.
- Set the sliders for Alarm Duration and Alarm Loudness.
- Tap < Edit Rule or click Back.
- Tap Done or click Save.
Note: This rule is not active until you activate the mode to which you added the siren trigger.
