How do I view Arlo Baby's air sensor data or history?
You can view live air sensor data or up to seven days of air sensor history in the Arlo app.
To view live air sensor data:
  1. Launch the Arlo app or log in to your Arlo account at my.arlo.com.
    The Devices page displays.
  2. On your Arlo Baby’s camera feed, tap or click Air sensorsto access air sensors.
    The icons for air quality Air quality, humidity Humidity, and temperature Temperature display.
    These icons are color coded so that you can tell at a glance if the sensor data is within the normal range for your home. Green is normal, and orange is abnormal or very abnormal.
  3. Note the current reading next to each icon.
To view Arlo Baby’s air sensor data history:
  2. On your Arlo Baby’s camera feed, tap or click Air sensors to access air sensors.
  3. To view a history of the past 12 hours, tap or click one of the icons for air quality Air quality, humidity Humidity, or temperature Temperature.
  4. Tap or click 24 hrs, 3 days, or 7 days to change your view.
For more information about Arlo Baby’s air sensors, see the following knowledge base articles:
