How do I manually turn on my Arlo Floodlight Camera?
Last updated: 24.02.2025
You have the option to manually turn your floodlight on or set it to trigger via automation.
To manually turn the floodlight on or off for your Arlo Pro 3 Floodlight Camera or Arlo Wired Floodlight Camera:
  1. Launch the Arlo Secure App.
  2. Tap Devices.
  3. Select the Arlo Wired Floodlight Camera or Arlo Pro 3 Floodlight Camera.
  4. Once in Live view, tap the switch on the bottom right.
    Note:
  5. Drag the slider left or right to increase or decrease the floodlight brightness.
    Note: Increasing the brightness uses a greater amount of battery life on the Arlo Floodlight Camera.
A countdown timer appears above the floodlight toggle when the light is turned on.
When the timer ends, the light will turn off.
