Before you mount your Arlo camera on a wall, make sure you have found a location with strong signal strength.
Note: Do not mount the camera until instructed to do so during the installation process.
You need the following items to mount your Arlo Camera:
- Power drill with a 15/64-inch (size B, 6mm) drill bit
- Phillips-head screwdriver
- Pencil
- The following items that came in the box with your camera:
- Mounting plate
- Screws
- Wall anchors
To mount your Arlo Camera on a wall:
- Using the mounting plate as a guide, mark pilot hole locations with a pencil.
- Use the marks as a guide for where to drill the pilot holes.
- Drill the pilot holes with a 15/64-inch (size B, 6mm) drill bit.
- Insert the wall anchors into the pre-drilled holes.
- With the arrow pointing up, align the mounting plate with the pre-drilled holes.
- Use the provided screws to secure the mounting plate to the wall.
- Align the camera with the mounting plate.
- Slide the camera onto the mounting plate to lock it into place.
- Test to make sure it feels secure and adjust the camera angle.
