How do I use the Arlo library filter?
You can use the filter to find and view recordings based on criteria that you select.
To filter your library content:
  1. Launch the Arlo app or log in to your Arlo account at my.arlo.com.
  2. Tap or click Library.
  3. Tap or click the Filter in the upper-left corner.
  4. Tap or click the filtering criteria that you want to use.
  5. Tap or click Done.
    Your Arlo library is now filtered according to your selected criteria.
