How do I use the Arlo library filter?
You can use the filter to find and view recordings based on criteria that you select.
To filter your library content:
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
- Tap or click Library.
- Tap or click the Filter in the upper-left corner.
- Tap or click the filtering criteria that you want to use.
- Tap or click Done.
Your Arlo library is now filtered according to your selected criteria.
