Arlo Pro 3 Floodlight Camera Product Tour
The Arlo Pro 3 Floodlight Camera has the following integrated features:
Arlo floodlight camera with labeled callouts highlighting key features, including the camera lens, spotlight, microphone, and motion sensor.
Rear view of an Arlo floodlight camera with labeled callouts identifying the sync button, charging port, and battery compartment.
Side view of an Arlo floodlight camera with labeled callouts highlighting the mounting bracket, battery housing, charging port, and floodlight assembly.
  1. Floodlight LED Panel: Brightly illuminate your property to improve safety and visibility. The floodlight brightness can be raised to a maximum brightness of 2000-3000 lumens (lm), depending on light settings in the Arlo Secure App. For more information, visit: How do I trigger the floodlight on my Arlo Pro 3 Floodlight Camera?
  2. Light Sensor: The light sensor enables the Dusk to Dawn setting on your camera’s floodlight. The light sensor also makes sure that your Arlo camera’s image is properly adjusted according to the settings.
  3. 2K Lens with 160-Degree Field of View: Never miss a detail with crystal clear 2K video quality and a wide viewing angle. For more information, visit: What is the field of view on my Arlo camera and how do I change it?
  4. Speaker: Deter intruders by activating the siren on the integrated speaker. For more information, visit: How do I turn the siren on my Arlo camera on or off?
  5. Microphone: Use the microphone and speaker for a full-duplex two-way conversation.
  6. Camera Status LED: Determine the status of your Arlo camera by referring to the status LED. For more information, visit: What do the different LED behaviors on my Arlo camera mean?
  7. Sync Button: Manually start the syncing process or factory reset your Arlo camera by pressing this button after releasing the camera from the camera housing. For more information, visit: How do I manually sync my Arlo camera to a SmartHub or Base Station?
  8. Magnetic Charging Port: Charge your Arlo Pro 3 Floodlight Camera outdoors with an Outdoor Magnetic Charging Cable. You can also use an Arlo Solar Panel for continuous power.
  9. Battery Access Button: Press the battery access button to replace your battery or to access the Sync button. For more information, visit: How do I change the battery in my Arlo Pro 3 Floodlight Camera?
  10. USB Charging Port: Charge your Arlo Pro 3 Floodlight Camera indoors without unscrewing or disassembling any mounting components. For more information, visit: How do I charge my Arlo Pro 3 Floodlight Camera?
  11. Weather-Resistant Camera Housing: Use your Arlo Pro 3 Floodlight Camera outdoors in a variety of weather conditions, including sun, wind, rain, and snow. For more information, visit: Are Arlo cameras weatherproof?
  12. Integrated Swivel Mount: Cover every angle, and mount your camera without the need for continuous power. For more information, visit: How should I position my Arlo Pro 3 Floodlight Camera?
  13. Mounting Wall Plate: Install the wall plate, then attach the swivel mount. For more information, visit: How do I wall-mount my Arlo Pro 3 Floodlight Camera?
