Arlo Chime 2 FAQ
Which Arlo devices are compatible with the Arlo Chime 2?
You can use the Arlo Chime 2 to ring an Arlo Video Doorbell or Arlo Audio Doorbell when the button is pressed. You can also set the Arlo Chime 2 to play a sound when a separate Arlo camera detects motion or audio.
Do I need an Arlo SmartHub or Base Station to use the Arlo Chime 2?
No. Your Arlo Chime 2 connects directly to your Wi-Fi router. After you connect your chime to a Wi-Fi router, you can pair it with an Arlo Video Doorbell.
Can I connect the Arlo Chime 2 to an Arlo SmartHub or Base Station?
No. You must connect your Arlo Chime 2 directly to your Wi-Fi router.
Can I use more than one Arlo Chime 2 with a single Arlo Doorbell?
Yes. You can pair an unlimited number of chimes to a single Arlo Doorbell.
Can I use more than one Arlo Video Doorbell with a single Arlo Chime 2?
Yes. You can pair more than one Arlo Video Doorbell with an Arlo Chime 2. For example, if you have two Arlo Video Doorbells, you can set both to trigger one Arlo Chime 2. You can also customize each doorbell melody, so you know which doorbell rang.
Does the Arlo Chime 2 run on battery power?
No. The Arlo Chime 2 must be plugged into a wall outlet indoors.
Can I use the Arlo Chime 2 outdoors?
No. The Arlo Chime 2 is meant for indoor use only.
Where should I place the Arlo Chime 2?
Place the Arlo Chime 2 within range of the Wi-Fi router that it is connected to.
Can I use the Arlo Chime 2 as a siren for an Arlo camera?
Yes. You can set the Arlo Chime 2 to activate the integrated siren when motion or audio is detected on your Arlo camera.
Can I change the chime melody that plays on my Arlo Chime 2?
Yes. You can change the chime melody in your Arlo doorbell’s melody settings within the Arlo Secure App.
Can I silence the Arlo Chime 2?
Yes. You can silence your Arlo Chime 2 by activating Silent Mode on your Arlo doorbell.
Related Support Articles
