This product tour shows images of the Arlo Essential Pan Tilt Security Camera 2K/HD (VMC3083/VMC2083). The information is also applicable to the Arlo Essential Pan Tilt Indoor Camera 2K/HD (VMC3073/VMC2073), except the indoor version does not include a spotlight or ambient light sensor.
Speaker and Microphone: Use the speaker and microphone to have a two-way conversation.
Pairing Button: Use the pairing button to install and factory reset the camera.
Status LED: Determine the status of your Arlo camera by referring to the LED indicator.
Ambient Light Sensor: The ambient light sensor is used to determine when to trigger the integrated spotlight.
Camera Lens: View your videos in full HD or 2K resolution with a 130-degree field of view.
Spotlight: Activate the integrated spotlight manually, or set it to trigger when motion is detected.
Power Connector: Use the USB cable to power your camera from an AC outlet.
