Protect your home with the Arlo Essential Solar Security Camera. The built-in solar panel charges the high-capacity battery. This solar-powered security camera operates on less than 20 days’ worth of sunshine a year. Secure your property and let the sun do the charging. The Integrated Solar Panel and high-capacity battery will keep your camera powered. Its ultra-slim design makes it easy to mount anywhere, while its modern look blends in perfectly with any home. You’ll also see more details with crystal-clear 2K video that is smooth and sharp. Intelligent alerts distinguish between people, packages, vehicles, and animals so you can focus on what matters and respond quickly, right from your phone. Hear and speak to visitors in your yard with 2-Way Audio or deter unwanted guests with the Integrated Siren. Clear Color Night Vision ensures you can keep an eye on your property in the dark, and 24/7 Emergency Response helps dispatch police, fire, or medical services in critical situations. With the Arlo Secure Early Warning System, you will be protected with smart detection, 60-Day Cloud Storage, and more. Easy to set up, wire-free, and comes with a trial of Arlo Secure Early Warning System for cloud storage and advanced AI features.
Product Features
- Available versions:
- VMC3090: 2560 x 1440p (2K)
- VMC2090: 1920 x 1080p (HD)
- High-Capacity Rechargeable Battery
- Integrated Solar Panel
- 130° diagonal field of view
- Clear Color Night Vision and IR Black and White
- Dual-Band Wi-Fi: 2.4 GHz and 5 GHz
- Wire-free installation
- 12x digital zoom
- AI-powered smart notification with Person, Vehicle, Animal, and Package Detection (Arlo Secure Early Warning System Plan required)
- Speaker and Microphone for Siren and 2-Way Talk
- One Tap Emergency Response (US only, Arlo Secure Early Warning System Plan required)
Video and Image
- Resolution:
- VMC3090: 2K (2560 x 1440)
- VMC2090: HD (1920 x 1080)
- Video formats: H.264, H.265
- 12x digital zoom
- Night vision range: Up to 25 ft (7.6 m)
- Integrated spotlight
Audio
- Two-Way Audio
- Built-In Siren
- Echo Cancellation
Power and Battery
- Integrated High-Capacity Rechargeable Battery
- Depending on settings, use, activity captured, and environment, the Arlo Essential Solar Camera operates on less than 20 days’ worth of sunshine a year.
- Indoor USB-C Charging Cable included with camera
- Additional accessory for battery charging: Outdoor USB-C Charging Cable VMA5700
Connectivity
- The Arlo Essential Solar Security Camera can connect directly to your Wi-Fi router or through an optional Arlo SmartHub.
- A SmartHub adds a secure personal network, helps manage Wi-Fi traffic, may improve battery life, and supports local storage.
- Compatible Arlo SmartHubs:
- VMB5000
- VMB4540
- Wi-Fi Support: 2.4 GHz and 5 GHz
- Wireless Range: Up to 300 ft (91 m) line of sight
- Requirements:
- High-speed internet connection
- Minimum 2 Mbps upload and download speed per camera
- Available Ethernet port on router for compatible SmartHub/Base Station setups
Durability
- IP-65 Weather-Resistant
- Designed for outdoor use and solar charging
- -4°F to 113°F (-20°C to 45°C) operating temperature
Dimensions and Weight
- Dimensions: 5.51 x 1.54 x 4.06 in (140 x 39 x 103 mm)
- Weight: 1.04 lb (470g)
Mounting Options
- Wall mount with screws and anchors included
In the Box
- Arlo Essential Solar Security Camera
- Wall Mount
- Screws
- Wall Anchors
- Quick Start Guide
Contents may vary by region or retail package.
Works With
- Apple Home (Arlo SmartHub Required)
- Amazon Alexa
- Google Assistant
- Samsung SmartThings
- IFTTT
- Arlo Secure Early Warning System subscription services
Support Status
- Sales Status: Current product
- Availability: Available for purchase
- Firmware Updates: Actively supported
Arlo Secure Early Warning System Trial
- This camera includes a trial of Arlo Secure Early Warning System.
- Learn what's included at What is included in the Arlo Secure Early Warning System trial?
