How is the Arlo Q picture and audio quality?
- Arlo Q delivers video in 1080p HD.
- It also comes with two-way audio so that you can both listen and talk back and forth.
How are Arlo Q cameras different from Arlo Wire-Free cameras?
- Arlo Wire-Free cameras are weatherproof and battery powered.
- Arlo Q cameras are AC powered and used indoors.
Do Arlo Q cameras record 24/7?
- To enable Arlo Q cameras to record 24/7, you will need a Continuous Video Recording plan.
- For more information, visit: What is Continuous Video Recording (CVR) and how do I use it?
Do I need a Base Station?
- You don't need a Base Station.
- Arlo Q cameras connect directly to your Wi-Fi router.
What is the maximum video resolution of Arlo Q cameras?
- Arlo Q cameras have a maximum 1080p HD resolution.
How far can I place my Arlo Q camera from my router?
- Place your Arlo camera within 300 feet of your Wi-Fi router.
- This distance can vary depending on obstacles such as concrete or stucco walls, metallic barriers, or Wi-Fi interference.
How far away does motion detection work on Arlo Q cameras?
- Arlo Q cameras can detect motion from as far as 50 feet away.
How much bandwidth does Arlo Q video streaming use?
- Arlo Q cameras use the following bandwidth when they are streaming:
- 1080P = 1500 kbps
- 720P = 700 kbps
- 480P = 300kbps
- 360P = 200kbps
- 240P = 100kbps
Do Arlo Q cameras have audio capability?
- Arlo Q cameras let you listen or speak to who or what is being viewed on the camera.
- Arlo Q cameras employ half-duplex transmission and work similarly to walkie-talkies.
Do I need batteries for my Arlo Q camera?
- Arlo Q cameras are AC powered cameras.
- You need to plug the camera into an electrical outlet.
What's in the Arlo Q box?
- 1 - VMC3040 camera
- 1 - Power adapter and cable
- 1 - Wall mount plate
- 4 - Mounting screws
- 1 - Arlo window decal
- 1 - Quick start guide
