Before you begin, you need a Phillips-head screwdriver to remove your Arlo Pro 3 Floodlight Camera from the wall. You can use the same screwdriver that you used to install the camera to the wall.
Note: To charge your camera indoors, you do not need to remove the entire camera and mount. For more information, visit: How do I charge my Arlo Pro 3 Floodlight Camera?.
To remove your Arlo Pro 3 Floodlight Camera from the wall:
- Use a Phillips-head screwdriver to loosen the screw at the bottom of the camera housing’s grip.
- Turn the camera housing counter clockwise, and pull it from the back plate.
- Unscrew the screws from the wall plate, and remove the wall plate from your wall.
