How long do Arlo camera batteries last?
The following Arlo camera battery life expectations are based on average use and depend on settings and environment. Average use assumes that you are using the Optimized or Best Battery Life Power Management settings and that your cameras record less than three minutes per day. Increasing the length, quality, or quantity of video recordings decreases your battery life.
Approximate Arlo Camera Battery Life:
Arlo Essential Security Camera 2K/HD (3rd Gen)
  • 4 months with average use
Arlo Essential XL Security Camera 2K/HD (3rd Gen)
  • 16 months with average use
Arlo Essential Outdoor Camera 2K/HD (2nd Generation)
Arlo Essential XL Outdoor Camera 2K/HD (2nd Generation)
Arlo Pro Security Camera 2K (6th Gen)
  • 9 months with average use
Arlo Pro XL Security Camera 2K (6th Gen)
  • 18 months with average use
Arlo Pro 5
  • 8 months with average use
Arlo Pro 4
  • 6 months with average use
Arlo Ultra Security Camera 4K (3rd Gen)
Arlo Ultra XL Security Camera 4K (3rd Gen)
  • 12 months with average use
Arlo Ultra and Ultra 2
  • 5 months with average use
Arlo Go 2
  • Battery life when using cellular signal can vary depending on mobile signal strength
Arlo Pro 3 Floodlight
Arlo Essential and Essential Spotlight
Arlo Essential Spotlight XL
Arlo Pro and Arlo Pro 2
  • 3 months with average use
  • Battery life varies depending on mobile signal strength
Arlo Wire-Free (VMC3030)
The following factors can reduce battery life:
  • Cold temperatures below 32°F (0°C)
  • Low-light environments that require camera sensors to work harder
  • Weak connection to the Arlo SmartHub, Arlo Base Station, or Wi-Fi router
    • Weak connections are caused by distance, Wi-Fi interference, or solid object obstructions between the camera and Arlo SmartHub, Arlo Base Station, or Wi-Fi router
  • Frequent use of the camera spotlight or floodlight
    • Applicable to camera models that have a built-in floodlight or spotlight feature
  • Long video recordings
  • Low cellular signal strength (Arlo Go and Arlo Go 2 only)
For more information, visit: How can I extend Arlo camera battery life?
