What to do when Arlo is unable to discover your device during an install or setup directly to a Wi-Fi router?
Last updated: 09.02.2026
Use the following troubleshooting if you attempted to connect your Arlo device directly to a Wi-Fi router and Arlo failed to discover the device.
Steps mentioned in this article are applicable only to Arlo cameras that require WiFi QR code scanning. These are:
  • Arlo Pro 4, Pro 5
  • Arlo Pro 3 Floodlight
  • Arlo Essential Series 1st Generation
  • Arlo Video Doorbell Wired & Wire-Free 1st Generation
  • Arlo Go 2
  • Arlo Q, Arlo Baby
All newer Arlo devices use Bluetooth for installation.
If you need help installing your new Arlo device, you can contact our Arlo Support.
To troubleshoot Wi-Fi discovery:
    Make sure you are connecting your Arlo device to a 2.4 GHz Wi-Fi network.
    Make sure your phone or mobile device is connected to the same 2.4 GHz network that you are trying to connect your camera to.
    Make sure you typed the correct Wi-Fi network SSID (network name) and password.
    • The network SSID and password are case-sensitive and must be EXACTLY correct.
    • You can tap the password eye icon to view your password before submitting.
    Ensure your mobile device and Arlo camera are within the Wi-Fi signal range of your Wi-Fi router.
    • During setup, we recommend placing your camera within 10-15 feet (3-4.5 meters) of your Wi-Fi router.
    • After the camera is set up and connected, you can move the camera anyplace within range of your Wi-Fi router.
    Make sure the camera LED is blinking blue while the camera is being discovered.
    Note: The Arlo Video Doorbell LED ring blinks white.
    • The camera LED can time out if it blinks longer than two minutes without successfully connecting to your Wi-Fi network.
      • If the camera times out, press the sync button again.
    • Make sure the LED blinks blue for the entirety of the connection process.
    Make sure you heard the chime noise when your camera scanned the QR code.
    Verify that you are in range of your mobile network.
    • For portable Arlo products like Go series cameras, make sure there is an activated SIM card inserted into the camera.
    • Also ensure the camera is in range of your mobile network.
    Ensure you are not using a VPN on your mobile device.
    • If a VPN is used, disable the VPN connection.
    If you have checked and verified all of the above, factory reset your Arlo device.
