What key features does the Arlo Security Light system offer?
The Arlo Security Light pairs well with Arlo camera systems. You can create rules for your cameras when the Arlo Security Light detects motion. For example, if your Arlo Security Light detects motion, your Arlo Pro 2 camera starts recording. Arlo Security Lights also add extra security by illuminating areas of your home that your Arlo cameras monitor.
Your Arlo Security Light offers the following features:
- 100% wire-free. The Arlo Security Light is 100% wire-free, so you don’t need to worry about placing it near a power outlet.
- Water resistant. Your Arlo Security Light is IP65-certified, so you can place it indoors or outdoors.
- Rechargeable battery. Arlo Security Lights use rechargeable batteries. You can easily charge the batteries when they are low and save money by not having to buy disposable batteries.
- Smart controls. You can use the Arlo app to manage your lights from anywhere.
- Motion detection alerts. The Arlo Security Light sends alerts to your smartphone or email when it detects motion.
- 400 lumens. Your Arlo Security Light can provide up to 400 lumens to illuminate any outdoor or indoor area.
- Customizable settings. Using the Arlo app, you can customize various settings, such as the LED color, the brightness of the beam, and the width of the beam.
- Scheduling. You can set a schedule to automatically activate and deactivate your Arlo Light.
- Compatible with Arlo camera systems. You can set your Arlo cameras to record when your Arlo Security Light detects motion. For more information, see How do I set up my Arlo cameras and my Arlo Security Lights to trigger each other?.
- Millions of LED light color options. You can choose from over 16 million hues for LED light colors.
- IFTTT integration. You can create an IoT ecosystem by integrating your Arlo Security Lights with other IFTTT compatible devices.
- Compatible with Amazon Alexa. You can pair your Arlo Security Light with Amazon Alexa sand use voice commands to turn your light on or off. For more information, see What voice commands can I use with my Arlo Security Light system and Amazon Alexa?.
