How do I power cycle my Arlo Security Light?
To power cycle your Arlo Security Light:
- Remove the battery from your Arlo Security Light or remove the power cable from the USB port of your Arlo Security Light.
- Wait 20 seconds and then reinsert the battery or power cable into your Arlo Security Light.
Your Arlo Security Light attempts to communicate with the Arlo Bridge. After two minutes, your Arlo Security Light returns to its default armed mode. In the default armed mode, the Arlo Security Light settings are the following:
- Color. White
- Brightness. 50%
- Beam width. Flood
- Flash. Off
- Turn on duration (in low ambient brightness). 10 seconds.
