Arlo Pro 3 Product Tour
Arlo Pro 5, Pro 4, and Pro 3 cameras have the following features:
  1. Spotlight: Activate the integrated spotlight manually, or set it to trigger when motion is detected.
  2. Light Sensor: The light sensor makes sure that your Arlo camera image is properly adjusted according to the setting. For more information, visit: How do I use HDR with my Arlo camera?
  3. 2K Lens with 160-Degree Field of View: Never miss a detail with crystal clear 2K video quality and a wide viewing angle. For more information, visit: What is the field of view on Arlo cameras and how do I change it?
  4. Speaker: Deter intruders by activating the siren on the integrated speaker. For more information, visit: How do I turn the siren on my Arlo camera on or off?
  5. Microphone: Use the microphone and speaker for a full-duplex two-way conversation.
  6. Camera LED: Determine the status of your Arlo camera by referring to the LED. For more information, visit: What do the different LED behaviors on my Arlo camera mean?
  7. Weather Resistant Camera Housing: Use your Arlo camera indoors or outdoors. For more information, visit: Are Arlo cameras weatherproof?
  8. Sync Button: Manually onboard cameras by pressing the sync button after releasing the camera from the camera housing.
  9. Charging Port: Take advantage of a simpler charging solution with the magnetic charging cable that came with your camera. For more information, visit: How do I charge my Arlo Ultra 2, Ultra, Pro 5, Pro 4, Pro 3, or Go 2 camera with the magnetic charger?
  10. Battery Access Button: Press the battery access button to replace your batteries or access the sync button. For more information, visit: How do I change the battery in my Arlo Ultra, Ultra 2, Pro 3, Pro 4, or Pro 5 camera?
  11. Screw Mount Hole: Use the screw mount hole to attach your camera to an outdoor security mount.
