Does Arlo Pro 4 output 2K resolution?
Yes. Arlo Pro 4 outputs 2560 x 1440 resolution at 16 x 9 aspect ratio.
Do I need an Arlo SmartHub or Base Station to use Arlo Pro 4?
No. An Arlo SmartHub or Base Station is optional. You can connect Arlo Pro 4 directly to your Wi-Fi router.
What are the benefits of connecting my Arlo Pro 4 to a SmartHub or Base Station?
The Arlo SmartHub or Base Station helps to protect your footage by adding a secure, personal network to your router. The SmartHub or Base Station also helps to regulate Wi-Fi traffic, can improve battery life, and is compatible with local storage.
For more information, visit: Arlo SmartHub and Base Station Compatibility
How wide is the viewing angle on Arlo Pro 4?
The lens is a 160-degree diagonal lens with a matching wide range for motion detection.
What does color night vision mean?
Typical night-time video footage from security cameras is displayed in black and white. Arlo Pro 4 can output images in color, even at night.
What is High Dynamic Range (HDR)?
HDR solves the problem with over or under exposed images with both bright and dark areas in the same picture. Arlo Pro 4 automatically determines when to use HDR.
Can I use Arlo Pro 4 indoors and outdoors?
Yes. Arlo Pro 4 can be used indoors and is weather resistant for outdoor use. The magnetic charging cable that was included with your camera is for indoor use only. If you wish to charge your camera outside, you must use the Outdoor Magnetic Charging Cable.
Does Arlo Pro 4 have an integrated spotlight?
Yes. The spotlight turns on in low-light settings. You can also manually turn it on or off.
Does Arlo Pro 4 include an Arlo Secure trial?
Yes. Arlo Pro 4 comes with a trial of Arlo Secure.
Is Arlo Pro 4 compatible with the Arlo XL Rechargeable Battery & Housing?
Yes. Arlo Pro 4 is compatible with the Arlo XL Rechargeable Battery & Housing.
Is Arlo Pro 4 compatible with the Arlo Solar Panel?
Yes. Arlo Pro 4 is compatible with the VMA5600 Solar Panel.
For more information, visit: Arlo Solar Panel Compatibility
Am I able to mount my Arlo Pro 4 camera from a ceiling?
Yes. You can use the included magnetic mount to mount your Pro 4 camera on the ceiling. If you use a Anti-Theft Mount, you can purchase a Ceiling Adapter to mount your camera from the ceiling.
Does Arlo Pro 4 have an integrated siren?
Yes. A siren sound plays directly from the camera. It can be set to trigger manually or automatically when motion or audio is detected.
What is the minimum upload bandwidth speed required?
Arlo Pro 4 uses an average of 2 Mbps upload bandwidth per camera.
Does Pro 4 support full 2-way audio?
Yes. You are able to have full conversational audio with Arlo Pro 4.
Does 2K recording require a subscription?
Arlo Pro 4 cameras come with an Arlo Secure trial that allows 2K streaming and cloud recording. You can also record 2K clips to local storage with the use of an Arlo SmartHub or Base Station. When your trial expires, you will need to renew the subscription to continue 2K cloud recording.
For more information on Arlo subscription plans, visit: What Arlo subscription plans and cloud recording options are available?
For more information on local storage, visit: How do I set up local storage backups using my Arlo SmartHub or Base Station?
