Arlo Wired Floodlight Camera FAQ
This FAQ applies to the new Arlo Wired Floodlight Camera (FLW2001).
Floodlight Settings
  1. How bright is the floodlight?
    The floodlight on the Arlo Wired Floodlight Camera can be adjusted up to a brightness of 2000 lumens.
  2. Can I adjust the brightness setting on the floodlight?
    Yes. You can adjust the brightness between 1-100%.
    For more information, visit: How do I adjust the light settings on my Arlo Wired Floodlight Camera?
  3. Will the floodlight turn on during the daytime?
    The floodlight will turn on based on your Ambient Light Sensitivity settings. This allows you to adjust when the light activates.
    For more information, visit: What is Ambient Light Sensitivity and how does it work for my Arlo device?
  4. Does the floodlight offer different light patterns?
    Yes. You can adjust the light to constant or a pulsating pattern.
  5. Will the floodlight still operate if the camera goes offline?
    Yes. The floodlight on the Arlo Wired Floodlight Camera will still respond to motion detection and activate the floodlight. The camera will not record if the device is offline, but the floodlight will still respond to motion detection.
  6. Can I set the floodlight to turn on and off on a set schedule?
    Yes, you can set your Arlo Wired Floodlight Camera to run on a schedule or create an automation to control how and when it operates.
  7. Can I set the floodlight to trigger when motion is detected?
    Yes. The floodlight is set to trigger when motion is detected. You can adjust this setting in the Arlo Secure App.
  8. Will the floodlight remain on after motion recording stops?
    Yes, if you set the floodlight camera to record 'until motion stops', the floodlight will remain on for the amount of time determined in the device settings.
Image Quality & Audio
  1. How wide is the viewing angle on the Arlo Wired Floodlight Camera?
    The lens is a 160° diagonal lens.
    For more information, visit: What is the field of view on my Arlo camera and how do I change it?
  2. Does the Arlo Wired Floodlight Camera have a microphone?
    Yes. The Arlo Wired Floodlight Camera has a microphone that allows you to hear and speak to visitors.
  3. Does the Arlo Wired Floodlight Camera have an integrated siren?
    Yes. The siren can be set to trigger automatically when motion or sound is detected, or manually via the Arlo Secure App.
    For more information, visit: How do I turn the siren on my Arlo camera on or off?
Design and Installation
  1. Does the Arlo camera separate from the wired floodlight?
    No. The camera and floodlight are integrated together in the Arlo Wired Floodlight Camera.
  2. Does the Arlo Wired Floodlight Camera include mounting hardware?
    Yes. The Arlo Wired Floodlight Camera comes with the appropriate mounting hardware allowing you to mount the device on a wall or ceiling.
  3. Is the Arlo Wired Floodlight Camera weather-resistant?
    Yes. The Arlo Wired Floodlight Camera is weather-resistant and built to withstand heat, cold, rain, and sun.
  4. Are the lights and camera adjustable on the Arlo Wired Floodlight Camera?
    Yes, you can adjust the positioning of the lights and camera to your desired vantage point.
    For more information, visit: How do I adjust the camera and light position on my Arlo Wired Floodlight Camera?
Compatibility and Requirements
  1. Is the Arlo Wired Floodlight Camera compatible with my existing Arlo system?
    Yes. You can use your Arlo Wired Floodlight Camera to cross-trigger other devices.
    For more information, visit: How do I set up cross-triggering for my Arlo system?
  2. Does the Arlo Wired Floodlight Camera require a battery or charging?
    No. The Arlo Wired Floodlight Camera is hardwired so that it is constantly receiving power.
  3. What are the power requirements for the Arlo Wired Floodlight Camera?
    The Arlo Wired Floodlight Camera requires a 100-240V AC 50-60 Hz hardwired power source.
  4. What is the minimum internet speed I need to use the Arlo Wired Floodlight Camera?
    The Arlo Wired Floodlight Camera requires an upload speed of at least 2 Mbps per camera.
    For more information, visit: What are the minimum requirements for installing and using an Arlo system?
  5. Can I connect the Arlo Wired Floodlight Camera to an Arlo SmartHub or Arlo Base Station?
    Not at this time. Compatibility with the Arlo SmartHub and Base Station will be available in a later release.
