How to set up Arlo Cameras?
This article applies to Arlo Ultra series, Arlo Pro series (3 and above), and Arlo Essential Wire-Free series cameras. To connect and install other Arlo devices, visit the links under: Set up other Arlo devices
  • Note: For best results, use the instructions provided in the Arlo Secure App for Arlo camera setup.
Need Help?
If you need help installing your new Arlo device, you can reach Arlo Support via the Need Help? button in the Arlo Secure App or on my.arlo.com.
  • You may also join the Arlo Community where you can seek advice and solutions from experts and other Arlo customers.
Notes:
An Arlo SmartHub or Base Station is required for Arlo Pro 3 and Arlo Ultra series cameras.
An Arlo SmartHub or Base Station is optional for Arlo Essential Wire-Free series cameras and Arlo Pro 4 and above.
    To set up an Arlo camera with an Arlo SmartHub or Base Station:
    Note: Arlo Ultra series and Arlo Pro 3 must use an Arlo SmartHub or Base Station.
    1. Launch the Arlo Secure App.
    2. Tap Devices.
      Note: Make sure the correct Location where you want to add the camera is selected. For more information, visit: How do I switch my Location in the Arlo Secure App?
    3. Tap
    4. Tap Cameras.
    5. Tap Ultra SeriesPro Series, or Essential Series.
    6. Select your specific camera.
    7. Follow the in-app instructions for charging and battery installation (where applicable).
    8. Select an Arlo SmartHub (or Arlo Base Station).
      Note: If an Arlo SmartHub (or Arlo Base Station) is not installed, tap Add New SmartHub.
    9. Follow the in-app instructions for your specific camera to complete the setup.
    To set up Arlo Pro 4 and above or Arlo Essential wire-free camera directly to your Wi-Fi router:
      2. Tap Devices.
      3. Tap
      4. Tap Pro Series or Essential Series.
      5. Select your specific camera.
      6. Follow the in-app instructions for charging and battery installation (where applicable).
      7. Follow the in-app instructions to connect your camera to a Wi-Fi network.
      To set up other Arlo devices, visit:
      To troubleshoot setup issues, visit:
