Arlo Essential Outdoor Camera (2nd Generation) FAQ
This FAQ applies to the new Arlo Essential Outdoor Camera (2nd Generation)
What new 2nd Generation Arlo Essential Outdoor Camera models are available?
  • Arlo Essential Outdoor Camera 2K (VMC3050)
  • Arlo Essential XL Outdoor Camera 2K (VMC3052)
  • Arlo Essential Outdoor Camera HD (VMC2050)
  • Arlo Essential XL Outdoor Camera HD (VMC2052)
What is the difference between the four 2nd Generation Arlo Essential Outdoor Cameras?
Arlo Essential Outdoor HD and Arlo Essential XL Outdoor HD camera models capture video in 1080p resolution. Arlo Essential Outdoor 2K and Arlo Essential XL Outdoor 2K capture video in 2K resolution. All models have an aspect ratio of 16:9.
The Arlo Essential XL Outdoor 2K and HD cameras come with an integrated extra-length (XL) battery, which provides additional battery life.
What are the key features of the Arlo Essential Outdoor Camera (2nd Generation)?
  • Motion Detection Alerts
  • Color Night Vision
  • Noise-Canceling Audio
  • Integrated Spotlight
  • Integrated Siren
  • Weather Resistant
  • Direct to Wi-Fi Connection
Are the Arlo Essential Outdoor (2nd Generation) cameras completely wire-free?
Yes. The Arlo Essential Outdoor (2nd Generation) cameras are fully wire-free and powered with an integrated battery. However, you can use the Arlo Essential Solar Panel (2nd Generation) and Arlo Essential Outdoor Charging Cable (2nd Generation) to keep your camera outdoors with continuous power. For more information, visit: How do I charge my Arlo Essential Outdoor Camera (2nd Generation) camera?
Can I use the Arlo Essential Outdoor (2nd Generation) cameras indoors and outdoors?
Yes. The Arlo Essential Outdoor (2nd Generation) cameras are weather-resistant, wire-free, and outdoor compatible. They do not require a continuous AC power connection.
What is the minimum upload bandwidth speed required?
You must have a high-speed Internet connection that can sustain a minimum of 2 Mbps upload per Arlo Essential Outdoor Camera. For more information, visit: What are the minimum requirements for installing and using my Arlo system?
Do I need an Arlo SmartHub or Base Station to use the Arlo Essential Outdoor Camera (2nd Generation)?
No. You can connect the Arlo Essential Outdoor Camera directly to your 2.4 GHz Wi-Fi network without the need for an Arlo SmartHub or Base Station. If you want to connect your camera to a SmartHub or Base Station, you can connect it to a VMB5000, VMB4540, VMB4500, or VMB4000 SmartHub or Base Station.
What are the benefits of connecting my Arlo Essential Outdoor Camera (2nd Generation) to a SmartHub or Base Station?
The Arlo SmartHub or Base Station increases security by adding a secure, personal network to your router. The Arlo SmartHub or Base Station also helps to regulate Wi-Fi traffic, can improve battery life, and is compatible with local storage.
For more information, visit: What are the benefits of using an Arlo SmartHub or Base Station?
How wide is the Arlo Essential Outdoor Camera (2nd Generation) viewing angle?
The camera lens provides a 130-degree field of view (FOV).
How much longer does the Arlo Essential XL Outdoor Camera (2nd Generation) battery last?
The Arlo Essential XL Outdoor Camera 2K and Essential XL Outdoor Camera HD come with an integrated extra-length (XL) battery that lasts 16 to 24 months with typical usage. The Arlo Essential Outdoor Camera HD and Arlo Essential Outdoor Camera 2K both come with an integrated battery that lasts four to six months without charging.
Can I remove the battery in my Arlo Essential Outdoor (2nd Generation) camera?
No. The battery in your Arlo Essential Outdoor Camera is fully integrated and cannot be removed. You can recharge the Arlo Essential Outdoor Camera with the indoor charging cable that is included with the camera. For more information, visit: How do I charge my Arlo Essential Outdoor Camera (2nd Generation) camera?
What kind of charging cable can I use with my 2nd Generation Arlo Essential Outdoor Camera?
Your Arlo Essential Outdoor Camera (2nd Generation) comes with a USB-C charging cable that you can use to charge your camera indoors. You can also use the Arlo Essential Solar Panel (2nd Generation) or Arlo Essential Outdoor Charging Cable (2nd Generation) to charge your camera outdoors.
What kind of power adapter can I use with the indoor charging cable that came with my camera?
To charge your Arlo Essential Outdoor Camera (2nd Generation), plug the included charging cable into any USB power source. Power sources with higher wattage charge your camera faster, Arlo recommends using at least 5V-2A. For more information, visit: How do I charge my Arlo Essential Outdoor Camera (2nd Generation) camera?
Can I use my Arlo Essential Outdoor Camera (2nd Generation) to cross-trigger other Arlo cameras?
Yes. You can set your other Arlo cameras to record when your Arlo Essential Outdoor Camera (2nd Generation) detects motion.
What mounting options do I have with my Arlo Essential Outdoor Camera (2nd Generation)?
Your Arlo Essential Outdoor Camera (2nd Generation) comes with an adjustable screw mount that you can use indoors or outdoors. You can also visit Arlo.com to search for additional mounting accessories. For more information about mounting your camera, visit: How do I mount my Arlo Essential Outdoor Camera (2nd Generation) to a wall?
Are Arlo Protective Camera Covers available for my Arlo Essential Outdoor Camera (2nd Generation)?
Arlo Protective Covers are available for the Arlo Essential Outdoor Camera (2nd Generation). The silicone skins are UV and weather-resistant, and ideal for outdoor and indoor use. They have a convenient slip-on, slip-off design while providing access for mounting and battery charging. For more information, visit: Arlo.com
Are Arlo Essential Outdoor or XL Outdoor Cameras compatible with Apple Home?
Not yet. The Arlo team is working to support Apple Home compatibility for Essential Outdoor (2nd Generation) Cameras.
