Arlo Pro 5 Camera FAQ
What is the difference between Arlo Pro 5S and Arlo Pro 4?
Arlo Pro 5S offers all the same features as Arlo Pro 4 with the following additional capabilities:
  • Dual-Band Wi-Fi
    • Hassle-free setup, faster video loading, and less buffering with support for 2.4GHz and 5GHz networks.
  • Low Power Mode
    • Provides up to 30% more battery life.
  • Improved image quality
    • Enhanced image sensor provides higher quality video, especially in low light.
Does Arlo Pro 5S have 2K resolution?
Yes. Arlo Pro 5S features 2K (2560x1440) resolution at 16:9 aspect ratio.
Do I need an Arlo SmartHub or Base Station to use Arlo Pro 5S?
No. An Arlo SmartHub or Base Station is optional. You can connect Arlo Pro 5S directly to your Wi-Fi router.
What are the benefits of connecting my Arlo Pro 5S to a SmartHub or Base Station?
The Arlo SmartHub or Base Station increases security by adding a secure, personal network to your router. The Arlo SmartHub or Base Station also helps to regulate Wi-Fi traffic, can improve battery life, and is compatible with local storage. For more information, visit: What are the benefits of using an Arlo SmartHub or Base Station?
How wide is the viewing angle on Arlo Pro 5S?
The lens is a 160-degree diagonal lens with a matching wide range for motion detection.
What does color night vision mean?
Typical night-time video footage from security cameras displays in black and white. Arlo Pro 5S can output images in color, even at night.
What is High Dynamic Range (HDR)?
HDR solves the problem with over or under exposed images with both bright and dark areas in the same picture. Arlo Pro 5S automatically determines when to use HDR.
Can I use Arlo Pro 5S indoors and outdoors?
Yes. Arlo Pro 5S can be used indoors and is weather resistant for outdoor use. The included magnetic charging cable is for indoor use only. If you wish to charge your camera outside, you must use the Outdoor Magnetic Charging Cable.
Does Arlo Pro 5S have an integrated spotlight?
Yes. The spotlight turns on in low-light settings. You can also manually turn it on or off.
Does Arlo Pro 5S include an Arlo Secure trial?
Yes. Arlo Pro 5S comes with a trial of Arlo Secure. For more information, visit: What is Arlo Secure and how can I benefit from it?
Is Arlo Pro 5S compatible with the Arlo XL Rechargeable Battery & Housing?
Yes. Arlo Pro 5S is compatible with the Arlo XL Rechargeable Battery & Housing.
Is Arlo Pro 5S compatible with Arlo Solar Panels?
Yes. For specific information, visit:  Arlo Solar Panel Compatibility
Am I able to mount my Arlo Pro 5S camera from my ceiling?
Yes. You can use the included mount or a Magnetic Wall Mount to mount your Pro 5S camera on the ceiling. If you use a  Anti-Theft Mount, you can purchase a Ceiling Adapter to mount your camera from the ceiling.
Does Arlo Pro 5S have an integrated siren?
Yes. A siren sound plays directly from the camera. It can be set to trigger manually or automatically with motion or audio detection.
What is the minimum upload bandwidth speed required?
Arlo Pro 5S uses an average of 2 Mbps upload bandwidth per camera.
Does Arlo Pro 5S support full two-way audio?
Yes. Arlo Pro 5S has full two-way conversational audio.
Does 2K recording require a subscription?
Arlo Pro 5S cameras come with an Arlo Secure trial that allows 2K streaming and cloud recording. You can also record 2K clips to local storage with the use of an Arlo SmartHub or Base Station. When your trial expires, you will need to renew the subscription to continue 2K cloud recording. For more information on Arlo subscription plans, visit: What Arlo subscription plans and cloud recording options are available?
What smart home and voice assistant systems can I use with the Arlo Pro 5S Camera?
The Arlo Pro 5S Camera is compatible with Amazon Alexa, Google Home, If This Then That (IFTTT), and Samsung SmartThings.
For more information, visit: What smart home and voice assistant systems can I use with my Arlo devices?
