This article provides instructions for mounting your wired or wire-free Arlo Essential Video Doorbell. The wire-free version of the Arlo Essential Video Doorbell can be set up in either a wired or wire-free configuration, whereas the wired version can only be set up in a wired configuration. For guidelines about placement and positioning of your wire-free Arlo Essential Video Doorbell, visit How should I position my Arlo Essential Video Doorbell Wire-Free?.
All the items that you need to mount your doorbell came in the box with your Arlo Essential Video Doorbell. To review these items, refer to the quick start guide.
To mount your Arlo Essential Video Doorbell, you need the following:
To mount your Arlo Essential Video Doorbell Wired:
Note: You should here a click when the doorbell is secured.
To mount your Arlo Essential Video Doorbell Wire-Free:
