Like existing Arlo Wire-Free cameras, Arlo Pro Wire-Free HD Security Cameras are completely wire-free and have everything you need to keep an eye on the things you love, including HD video, weatherproof capability, night vision and several new features that make securing your home easier than ever.
Rechargeable batteries
Flexible Power Options
With Arlo Pro, you can choose to stay wire-free or go wired. If you want to plug in your cameras, Arlo Pro has you covered. Arlo Pro Wire-Free cameras can be plugged into an AC outlet with no batteries needed.
Note: You must use the supplied Arlo Pro power adapter and power adapter cable. The power adapter and power adapter cable are not weatherproof and must be used indoors.
2-way audio
Arlo Pro Wire-Free cameras have both a speaker and a microphone. Arlo Pro lets you record video with audio, send alerts triggered by sound, and even talk through the camera's speaker using the Arlo app. Like motion detection sensitivity, audio detection sensitivity can be adjusted in a camera's rules using the Arlo app or the web interface. For more information about changing audio sensitivity settings, see How do I change the audio sensitivity on my Arlo Q, Arlo Q Plus, or Arlo Pro Wire-Free cameras?.
Advanced motion detection sensor
Mix-and-match compatibility with other Arlo products
If you are already using Arlo products, you can keep using them. You can sync new Arlo Pro Wire-Free cameras with an existing Arlo base station or use a new Arlo Pro base station with your existing Arlo Wire-Free cameras. You can even mix and match existing Arlo Wire-Free cameras and new Arlo Pro Wire-Free cameras. No matter what models you're using, Arlo keeps you covered from every angle.
Siren
Local storage backup
Arlo Pro lets you connect a USB drive to the base station for local backup storage. For more information about setting up local storage, see How do I set up local storage backups on a USB device using my Arlo Pro base station?.
New skins
